DOHC 2 itre engine
oldbillkane - 19/5/03 at 08:00 AM
Can anyone tell me if this motor will slot in to the 'book' chassis without having to have bonnet bulges on the top. I intend to replace the EFI with twin webers.. Is this a fairly staight forward fit.
James - 19/5/03 at 10:12 AM
Got a feeling it's even taller than the Pinto
Also, bear in mind the MT75 gearbox is different shape to the Type9 too so may be harder to fit in tunnel.
James
stephen_gusterson - 19/5/03 at 12:00 PM
think you will find even the pinto is a struggle.
If I were you id go to the scrappy with a tape measure and compare
atb
steve
Jon Bradbury - 20/5/03 at 08:18 AM
The DOHC is a bigger engine than the Pinto for sure. That is why Robon Hood Engineering redesigned their 2B chassis to take it.
I am building one of these kits BTW...
