4age injector blanks
COREdevelopments - 16/3/06 at 09:17 AM
hello all
im using the 4age on dellortos. now i would like some sugestions on blanking off the injector holes. i was thinking of making up some tophats out of aluminium??
any tips
Prez - 16/3/06 at 11:13 AM
I will have this job to do as well in the near future, I was just going to turn some aluminium plugs as a push fit to the injector holes and put a rubber washer underneath and a bit of sealant to stop any air getting in. Top hat sounds like a good idea, as it would make it easier to get them out should you ever want to. I'd be interested to see your solution in any case.
Adam
NS Dev - 16/3/06 at 11:33 AM
ally top hats and a dab of loctite
Mix - 16/3/06 at 12:21 PM
Alloy top hats with an O ring groove cut into them, use an O ring and forget the loctite.
Mick
Ben Smith - 16/3/06 at 01:26 PM
My injectors were block off with large grub screws. This is how RAW do it. Just be careful not to get any metal in engine when tapping holes!!
Ben.
COREdevelopments - 16/3/06 at 07:37 PM
the carbs are already bolted on now so dont wanna go cutting threads. its bit of a bitch to get all the carbs set up off, top hat with o ring sounds good to me. cheers guys appreciate the comments
Rob
