ebay sva kits
Toady1 - 23/6/06 at 07:39 PM
are the kits on ebay for covering the nuts etc worth buying or can you buy cheaper stuff from your local diy/motor factors etc?
richard thomas - 23/6/06 at 08:28 PM
Put it this way, i failed sva yesterday because i had covered my track control arms with foam. the tester said he would not pass it because that's not what a major manufacturer would use and advised using the type you see on ebay because he is allowed to pass those. i had also covered the top balljoint and he said i didn't need to because the sphere didn't touch it.
cheers, rich.
Chippy - 23/6/06 at 09:31 PM
Best covers for TCA/Track rod ends. Go to your local electrical suppliers and get two 22mm cones that go over Pyro connectors, cut end of cone to be a tight fit on the rod, and slide over the T/R ball joints, job done. Chippy
By the way, cheap as chips!!!
[Edited on 23-6-06 by Chippy]
rusty nuts - 24/6/06 at 06:44 AM
Agree with Chippy but I filled mine with silicon after sliding into place to give them a bit of "body" just in case . Not sure tester even felt them though
tom_loughlin - 24/6/06 at 08:39 AM
I just used convuluted tubing on mine, cable tied in place. Done neatly, it doesntlook bad at all.
I usedthis method for the top ball joints as well as the steering rack extensions.
And to cover the coilovers, I used the old gaitors off the sierra steering rack, again, cable tied down.
Saved paying for something off ebay that you'll probably never use again.
All the best
Tom
[Edited on 24/6/06 by tom_loughlin]
Toady1 - 24/6/06 at 08:46 AM
cheers guys, in that case ill get myself a set as its only a 10'er!
BKLOCO - 24/6/06 at 08:47 AM
I used self amalgamating tape on track rods etc. SVA guy said it was fine.
speedthing - 24/6/06 at 09:31 AM
Toad don't buy the sva kit yet as i've been sorting stuff out in the garage and i have some ball joint and nut covers that are going with the indy infact anything i find will be going with the kit
[Edited on 24/6/06 by speedthing
[Edited on 24/6/06 by speedthing]
Toady1 - 24/6/06 at 09:36 AM
cool thanks matey!
