master cylinder robin hood
kylerichmond - 19/6/10 at 07:09 PM
I have fitted a zetec to my robin hood replacing the into, however to get the inlet manifold with bike crabs to clear the brake master cylinder I'm going to fit a fiat punt unit with remote reservoir, would this cylinder provide sufficient braking to the sierra brake callers fitted?, I'm using this cylinder as space is an issue
Confused but excited. - 19/6/10 at 08:47 PM
Bike crabs? Fiat punt? Are you building a boat?
This is a car forum.
kylerichmond - 19/6/10 at 10:44 PM
Punto,
carbs
snapper - 20/6/10 at 06:19 AM
Should be fine, should only make a difference to the brake pedal effort, this can be modified by changing the attachment point of the master cylinder to the lever .
There are diagrams in the Rally Design catalog, Wilwood page.
kylerichmond - 20/6/10 at 09:13 AM
Cheers snapped will try it and see what happens
theconrodkid - 20/6/10 at 02:13 PM
the fiat m/c is a smaller dia and will improve the brakes 100% (ish)
