1.9 or 2.25" shocks
ady8077 - 2/11/04 at 06:12 PM
Hi
Do 1.9" shocks have the same damping characteristics as 2.25"?
Their quite a bit lighter
Adrian
chrisg - 2/11/04 at 07:17 PM
Springs don't really have damping charicteristics, they're rated according to there stiffness eg.160 pounds per inch - the load required to compress the spring by one inch, and so a 1.9 spring rated at 160/inch is the same as a 2.25 spring rated at 160/inch, the only difference is the diameter, which obviously needs to match the spring seats on your chosen shock.
You can't swap spring sizes on the same shock, so your choice of spring depends on the shock you choose.
HTH
Chris
gazza285 - 2/11/04 at 07:35 PM
Yes. Although it all depends on what money you spend as to what quality you get as usual.
cosworth - 2/11/04 at 09:13 PM
2.25" springs are better than 1.9" springs. They are less likely to bend, although on a locost they are so short that it probably will make little difference
gazza285 - 2/11/04 at 09:28 PM
Originally posted by Dave Ashurst
I think Adrian is asking whether smaller, lighter shocks can provide adequate damping (?)
That was the question I was answering!
Most modern mono tube shocks do not generate heat like the old twin tubes and as they are usually hanging out in the breeze in a Locost, I can't see overheating being a problem. Unless you are buying cheap twin tubes, hence the comment about how much money you spend as to the quality.
ady8077 - 2/11/04 at 09:58 PM
Hi
Thanks for the replies
Chrisg, i was talking about shocks not springs
The shocks in question are GAZ, the 1.9" ones are cheaper, just woundered why
Adrian
