Service brake calper old wilwood model?
HPDxxx - 8/5/17 at 03:34 PM
hello,
i have this calipers and i need to service it...
look like an old model of wildood.
diameter of piston is 38.03mm (1,497"
seals have a square section
i have sent a request to burton power some days ago but without answer..
thanks
gremlin1234 - 8/5/17 at 03:57 PM
you may have found this link already, but it will be useful to anyone else searching too ;-)
http://www.wilwood.com/Pdf/howtostories/Caliper_Rebuild.pdf
Doctor Derek Doctors - 8/5/17 at 05:22 PM
Don't rally design stock Wilwood service kits? I would assume that the seal kits are based on piston size rather that calipers type so a modern rebuild kit for the a calipers with the same size piston may work.
obfripper - 8/5/17 at 05:53 PM
Those look like raceleda/bremsport/outlaw m16 calipers, i don't think wilwood made any lug mount m16 replacements.
Afaik there is no difference between the 3 brands so the service kits should be cross compatible.
Have a look here, they might list uk dealers and service kits.
http://www.outlawdiscbrakes.com/
Dave
gremlin1234 - 8/5/17 at 07:11 PM
wilwoods catalog is here
http://www.wilwood.com/Pdf/Catalogs/TechCatalog.pdf
[Edited on 8/5/17 by gremlin1234]
HPDxxx - 9/5/17 at 08:22 AM
thanks i have just open calipers and clean all parts like in the pdf you have linked.. the problem for me is find the right dimension of seals.
i have asked to many brake shops here but with this size they haven't.
i can ask to rallydesign too... yes i think it's important only the piston size for reference
Dave
thankyou dave! i have read on forum about raceleda/bremsport/outlaw m16 calipers but I thought they were out of production.
i'll write immediatly a mail to outlaw.
my consideration about wilwoo is related to type of pads that exatly match the dynalite one.
thankyou too... i have just looked to wilwood catalogue but there isn't calipers with 1,5" pistons...
catalog is here
i have looked few days ago but there isn't piston in 1,5" size...
Schrodinger - 9/5/17 at 08:27 AM
Have you tried contacting Westfield? they ought to know who supplied them with the calipers.
sdh2903 - 9/5/17 at 08:42 AM
They could be hispec calipers or as above outlaw/bremsport. Def not wilwoods.
adithorp - 9/5/17 at 09:32 AM
I was thinking they looked more like hi-spec as well.
Madinventions - 9/5/17 at 02:36 PM
Or just send them off to Bigg Red for a refurb. Back inside a week fully rebuilt and tested.
