I have nice CF wings from CarbonMods that I don't want to wreck. People have put little notches in the bends of their stays, so that the flat part goes UNDER the fender itself, and not through the edge. How is this done?
Really the best way is to buy a blow torch and heat the metal up till its glowing.
With a little practice with the metal in the vice you'll find it very easy to bend just where you want.
Let the metal cool naturally, no dipping in water as doing that would make the metal brittle
After the original style stays broke, I made some new ones myself from thicker and wider flat bar. To get under the lip of the wing, I ended up having
a short stretch of angle between the upright bit and the bit under the wing, sort of like this:
if that makes sense. Doing it that way avoided having to do an extra bend like this:
_|
Edit - the lines don;t show up very well but hopefully you can see what I'm on about
[Edited on 13.02.2009 by Humbug]
My wings have a right angle 90 degree bend between the part over the tyre and the lip, and require the second type.
And though I appreciate the advice Whippy, I am NOT taking these off after what I went through to get the stays on!
this is looking like another one of those jobs to hire someone for. I don't want to destroy $500 worth of fenders!!
[Edited on 13/2/09 by RK]
I thought most folk bolted the stays on using the uprights brake mud shield bolts holes (usually 3 of them)
How have you fix your ones on?
glad to hear you are still plugging away RK. Keep it up mate.
[Edited on 13/2/09 by Dangle_kt]
Mine were made by 20mm wide 5mm thick steel bar. Put them in a vice and walloped them with a big hammer. Job done.
Hey, that's the ticket!
Oh, I'm not close to giving up. I don't really have a lot to do besides:
1. make a bonnet
2. mount the nosecone, scuttle, rear arches and front wings
3. install passenger seat/ seatbelts
4. wire the car (dash wired over the past couple of weeks) - engine wired now, loom and fusebox installed, ready for lights etc
5. install windshield/wiper transmission boxes
6. install lights
7. washer nozzle
Other than that, done. Can't do painting til it warms up, but ready with the spray gun and compressor!
