What screws have you used to attach the windscreen to the pillars.
The windscreen frame looks very small in cross section to get a decent screw in, and there appears to be a lot of resistance from the rubber under the
screen. I am concerned that the this will not be a strong section. Any comments appreciated.
John
I'd tap a thread into the alloy frame, say an M5 thread and use countersunk screws going through the support. Use 3 -4 per side
Mt Caterham screen has rivnuts in the frame.
Stu
I used 3 m3 tapped into the frame.
Using something as big as M5 do they not break through and hit the glass. I am worried that M3 will not be strong enough to overcome the stress from the rubber
I use blind studs that are set in the frame and dont crack glass
