Before I commit myself and glue and bolt the rear arches on, I thought a question to the forum may not be a bad thing.
Fibre glass rear arches and aluminium body panels. I was planning to use m6 bolts/screws with large washers spaced aprox 5 or 6 inches apart and
sikaflex around the outer edgesof the flange to prevent water ingress between the surfaces of fibre glass and aluminium.
Is sikaflex too much, should I suse a standard sealent so I can seperate them if required?
What methods have you used to secure your wings?
Adrian
Use a strip of "P" rubber, available from CBS
RD
I just used the normal tadpole trim at the joint and bolted it like you suggest. No problems so far...
Rich
That's what I did but using silicon sealer, the correct way is rubber extrusion, the stuff that looks like a 'P' in cross section.
If you just want to seal but not stick then cover the wing in celophane, attach/bolt and seal as usual with silicon, remove when cured, peel off the
celophane you will now have a perfect seal.
Regards Mark
you dont need that many bolts. 6 will be enough
OK thanks for the replies.
Just a few jobs to go.
Adrian
