As the title goes, i will need to fit a small one where my air filter used to be, was thinking of filling the hole but don't want it to crack,
and then fit the one at the front of the bonnet line like the Mach#1.
Its a ali bonnet.
And a close up....
Why would filling in an ali bonnet crack?
Pics below show:
a) small scoop
b) patch where the old manifold used to go over the side rail
Both not too difficult to do and look fairly neat (IMHO
Whats the verdict with these scoops,,obviously catches the cold air and drives it in at speed, my filter stick's out the bonnet about 4" just to get the carb's to work properly. Would i benefit?
iiyama, can't see the pics, i know ali won't crack its just if i put a glass fibre scoop over i don't want cracks, if it does not cover the hole from my old K&N it was a pinto so on the lhs.
Yep Humbug, yours looks simple and efective, i think i may have some ali left.
Originally posted by iiyama
And a close up....
scoop
I just need mine to clear the VVC solenoid. £4 off ebay.
ATB Dan.
When I said large, I meant it.
Got to cover an Integrale Turbo lump, which is quite tall.
Have made a bulge as attached, but not happy with it
Want to cut the old bump out & bolt on a carbon one that's a decent shape.
Hello MattD, some time ago I posted a series of threads covering among other things the making of bonnet bulges and scoops in aluminium using just
hand tools. It is easy to do and you can make the exact shape you need for the job. The thread can be found in the Tools and Techniques section. here
is the link:
http://www.locostbuilders.co.uk/forum/37/viewthread.php?tid=145585
I'll be happy to answer any queries you may have. Please feel free to drop me a U2U.
[Edited on 14/6/11 by 2cv]
Originally posted by 2cv
Hello MattD, some time ago I posted a series of threads covering among other things the making of bonnet bulges and scoops in aluminium using just hand tools. It is easy to do and you can make the exact shape you need for the job. The thread can be found in the Tools and Techniques section. here is the link:
Originally posted by franky
No this is a black GRP one, same size as the carbon mods one. GKD sell them
I've a carbon mods one i'm going to sell when I get round to it though....
It gives me about 2 inch to clear the linkage on my throttle bodies.
code:
Cheers for the reply - will take a look. It's the surface finish in Ali that I'd be worried about !
Just a quick question.
Whats the best way of fixing to bonnet, mine is grp scoop and bonnet, silkaflex, bolt, or bond it on?
Dont want it ripping off at speed.
[Edited on 14/6/11 by sky12042]
If I were fitting an aluminium one to a fibreglass bonnet, I'd make it with a flange, insert it from the underside of the bonnet and bond it with panel adhesive. I wouldn't use countersunk rivets because even filled you will see where they are.
is it a twin cam or 8valve? 1600 or 2000
Some years ago I built a Sylva Phoenix into which I fitted a Cosworth YB engine. A large bonnet bulge was needed to accommodate the height of the
engine and I made this in aluminium. I hope pictures follow. John
Hammerform
Forming
Fitted
Finished
[Edited on 15/6/11 by John Bonnett]
picts of the engine pleaseis it a twin cam or 8valve? 1600 or 2000
Matt, you have U2U mate.
Originally posted by John Bonnett
Some years ago I built a Sylva Phoenix into which I fitted a Cosworth YB engine. A large bonnet bulge was needed to accommodate the height of the engine and I made this in aluminium. I hope pictures follow. John
Hammerform
Forming
Fitted
Finished
