Ok, due to the lack of room in the garage (despite a new garage door), my original plan to make a fibreglass front end is out the window and i have
decided to make a metal frame from 10X10x1mm strips of steel and 1mm steel sheet over the top.
Has anyone built a bonnet like this and maybe has some advice?
Also, has anyone painted their car when it is built up rather than each panel individually?
Paint it as the last job, its a locost not a kit so thing will be fitted on and of all the time and things get marked.
1 mm steel? most peeps use 1.5 mm to 2 mm aluminium - that is gonna wiegh a fair but; assuming you are building a 7 type car.
