Rear suspension tops
ChrisW - 18/10/01 at 10:23 PM
Another one for you guys!
Going to weld the plates that will hold the top shock brackets at the rear but surely as it's welded on three sides it will be impossible to bolt the shock in? Should the bracket be bigger or is a spacer the way to go?
Chris
