Hi,
I have cut a hole in my bonnet - I now need a scoop to cover the inlet manifold any suggestions.
I also need an air filter suggestions also welcome.
thanks
Frank
Do you really want a scoop?
I would have thought a bulge would look much nicer...
Either way... you could make one yourself using insulation foam as a mold....
That way it would fit perfectly... much better IMHO than bolting on something generic
Wont take long to make a bulge from fibreglass
Edit to say... do you not have an airfilter/induction pipework to go on there too?
[Edited on 13/2/10 by tegwin]
Beat one out of ally sheet. I don't think you'll get one off the shelf to fit that on the curve of the bonnet.
Or fit a different inlet manifold and air filter which won't stick up - then patch or replace the bonnet.
trim it up a bit neater and polish or paint the inlet.
display it , it may look better ?
it's not finish yet but I've done that on mine. You will have to make it bigger to fit yours. I used a kitchen plate as a mould to make it.
And then cut it in the good dimension.
