Had a good day doing a bit of work on the jag and alot on the locost.
I made a frame for the front during the week and welded up the bottom rear bracket this afternoon and got it all bolted on. I also had to shift more
junk at the back of the garage to allow the door to shut with the wing bolted on
Front frame
Bottom bracket
Wing bolted on - Looks very wide in the pic but not so much in real life
Wheel clearance - Is this going to be a potential IVA issue or should i fit mud flaps?
[Edited on 7-3-10 by speedyxjs]
im lost...
i thought it was going to be a locost 7 thing....
what is it going to be???
me too, is this a fury or phoenix build? i too thought it was going to be 7esq
Its sevenesque except the front
The wings are TR6 and im just hoping it looks a bit better that it does at the moment.
interesting! be good to ee an idea of the body and how you are going to join the two body types, a challenge indeed!
With regards to your IVA issue i would say tour guess is as good as anyones! I would say it is fine but perhaps someone with a fury or similar will be
able to give you some wiser words!
Of course, to cover your back it woudn't be too much effort to put mud flaps on with a little bracket that could always fall off on the drive
home?
Im aiming for something similar to this:
My car is only 10cm wider
It's an interestig prospect - I had an idea to do something similar with a midget or forgeye body over a modified 7 style chassis.
Wht are you going to do for the bumper/bonnet?
so are we looking at tr6 body on a 7 chassis with jag powwweeeerrrr?!
Originally posted by speedyxjs
And if it turns out fugly, il resort to normal seven post IVA
"should i fit mud flaps? "
Yes, but make sure they are chequered. They were good for another 5mph in the mid sixties. Those and a racing stripe were popular cheap tuning aids
back in the day.
Yes, but make sure they are chequered. They were good for another 5mph in the mid sixties. Those and a racing stripe were popular cheap tuning aids back in the day.
I assume weights not an issue then?
with a six pot jag engine?
probably not
