I managed to make a right hash of bending my wingstays - somehow I bent them in completely the wrong direction! What a &%@*!!!, anyway I tried to
bend them back today and as I suspected they just cracked, tried heat, no heat, slow fast all with the same outcome.
So, is it worth welding them or are they doomed to early failure?
i'd remake them personally,it'll only be on the back of your mind
If you are a good welder then weld them if not re-make
Don't for the life of me understand why if people make a mess of them they go out and by new ones.
very carefully cut thru the top of the flattened tube just before the weld. only thru the tube both sides and ends. the flat bar can then be pulled
out and bracket re-used.
now you can bend some new flat bar to the desired shape and when you're happy put the flat bar back in the bracket and weld it up.
I cut the bar out even before I even tried bending the bar
tony
tony
very carefully cut thru the top of the flattened tube just before the weld. only thru the tube both sides and ends. the flat bar can then be pulled out and bracket re-used.
tony
tony
Cheers fellas, unfortunately I can't weld (yet) although I think it's about time I learned! I think I'll get my self a welder and give
it a go, got plenty to practice on. Thanks for the advice.
Ez
