Which Filler Cap??
Dick Axtell - 5/4/10 at 04:16 PM
Will be looking for one at Stoneleigh, but not too sure which would be best.
Plan to fit it in top panel, covering boot & tank space. Have noted various comments on this section of Forum re this installation.
So, which version would you recommend? And from which supplier?
Macbeast - 5/4/10 at 04:33 PM
Bear in mind IVA requirement for captive filler cap. Also lead-free restrictor ( not that you can buy leaded anywhere ).
irvined - 5/4/10 at 04:50 PM
For IVA it must:
Have a positive locking action - ie, something to stop it falling off when you hit a bump, some inspectors interpret this to being a security lock.
Have a lead restrictor fitted (unless you run leaded.)
Must be secured to the vehicle, or incorporate a lock, that when unlocked, does not allow the key to be removed.
I haven't found an aero style filler that meets all of those out the box, so I used some chain from a sink to tether it. I have some pictures and a write up here
RK - 6/4/10 at 10:28 PM
It seems the ones to get are the flush fit, with the neck included. Otherwise, the "much less expensive" bike caps, don't have this, and you either need to buy/make/scrounge one, making the price fairly equal. However, that said, I don't see why an old filler neck from any old car wouldn't work. Maybe someone can enlighten us on this.
Dick Axtell - 7/4/10 at 03:21 PM
Thanks for the feedback, guys, and thanks also to David for those photos.
Have noted the IVA points, and will be testing a few examples at Stoneleigh.
