I have got my hands on some 10" wide wheels for the rear of the car and some 8s for the front. The problem is with the rears taht I need to
widen the wheel arch to cover the wheels. As this car is used for sprinting and will never see the road I would like to do them in rubber that will
have a groove in it so I can just push it on the Grp.I have seen similar used on the front of some rally cars but everyone I speak to has no idea
where to get it from. The choice of rubber is that chicanes,cones and pallets dont tend to move easily so if I do "get a little to close"
there is some give in the srches ratjer than smash the Grp
Any ideas guys
Hi, had similar scenario with Jago - fitted bigger wider wheels for better handling and cool looks [and also instant MOT failure
due to 4
protruding wheels]
Looked at rubber but too floppy,
looked pants anyway; thought of alu but have watched the Kung fool movies with bits of metal slicing people up.
so we settled on ABS - tough yet springy, self supporting, easy to work , free, etc, made some angle shaped peces ( hot air gun and lots of clamps)
and riveted to edge of front wing lip. For the back we just bolted a wide strip to body tub, finished edges with some u trim
a few pics
have some pics of the angled bits somewhere but this should give you an idea
atb
Mike
Erm excuse my ignorance and lack of education but what is ABS and where do I get it
Brian
Thermoplastic sheet as used for car dash boards and moulded door panels- also comes in carbon fibre "sort of look a like"- have a look on
the web.
Ideally you need to find a local factory using the stuff and get a few long off cut strips.
What colour is your car
atb
Mike
or Acrylonitrile butadiene styrene (need a QI smiley
Polycarbonate would also work well but the colour range is limited. Might even find something suitable in B&Q.
If you can't find offcuts or a local plastic supplier ebay always has plenty of both.
ebay ABS
ebay polycarbonate
Thanks guys
I have now "procured" something that will do the trick. You know the hoardings that go up around demolition/building sites and the
contractor has those signs with the company name etc on them(about 2 foot by 4 foot) well I say no more
By the way the car is Black and dusty but soon to have the dust blown off it
Brian
