Help please!
How can you work out the correct position to drill the scuttle for the wiper spindle holes?
Thanks in advance
Work out the sweep in angles, work out the length of the blades and arms, work out where you want the blades to be then work backwards. Quite tricky to do. I did the passenger side first and it was a few CM out so when I did the drivers side I compensated for it.
Not a job to attempt with a hangover then!
Thanks a lot for all your help
Some links that hopefully will be of help (on an MK)
Measurements
Link
Hood (if your interested)
