Alluminium Rear Panel Locost McSorley+442
m0csi - 27/7/10 at 08:52 AM
Can anyone help ... I am looking for a rear panel for my locost ... I could buy a alluminium sheet to shape ... but not got the tools ... Anyone know where I can get one made ... Thanks Mike ...
interestedparty - 27/7/10 at 09:00 AM
Buy a cheap jigsaw and some decent hacksat blades, and if you don't already have them a cordless drill with some 4mm bits, some 4mm rivets and a rivet gun, that lot will still be a lot cheaper than getting someone else to do it, and you can always sell them after
m0csi - 27/7/10 at 09:07 AM
Hi ... Thanks for your prompt reply ... The problem will be the roll around the sides ... how did you go on doing yours ... Thanks again ... Mike ...
nige - 27/7/10 at 09:30 AM
i used a fibre glass one and cut n shut
cut it and then clamp it with some 2x2
timber then fibre glass the join
then add some on the bottom
interestedparty - 27/7/10 at 10:52 AM
I'm not using aluminium myself. Do you have the build your own sportscar book from Haynes, there is a section on it in there.
ashg - 27/7/10 at 11:32 AM
have a look in my photo bucket there are some pictures showing how to do it in there.
http://s707.photobucket.com/albums/ww75/ashgardiner/
all you need is a sheet of ali something to cut it with, a roll of wall lining paper to make the template and plenty of clamps, scraps of wood. rivets to hold it on and finally a couple of different size hammers.
edit: If a fool like me can manage it then anyone can
[Edited on 27/7/10 by ashg]
scoop - 27/7/10 at 05:53 PM
I put a thread on here a couple of years ago and got a lot of good advice. i didnt even make a template. Just need patience and nylon hammers not metal. You just take a few nicks out above the curves and beat it evenly and slowly. When you have marked the hammer just sand it smooth and start again.
m0csi - 27/7/10 at 11:41 PM
Thanks all for the advice going to make own ... Think the bonnet will be the most difficult ... Mike
