I’m building an exoskeleton car with ½” tube and I’m planning to have as little bodywork as possible. The gaps in the frame a mostly triangles with
sides of about 200mm but the centre line of the car from the nose to the central steering wheel will have 180mm square holes – big enough for the MSVA
sphere of doom to get through.
Just below the surface of the car will be the fillers for the coolant and brake fluid plus a little further in are the top wishbone and damper mounts
plus the top of the radiator. Is the MSVA inspector going to be troubled by what the sphere can contact inside the “nose cone” of the car like this?
Do I need to cover it up?
Was going to post something similar... will be watching with interest!
Is it possible to put a front bumper bar on so this becomes the critical area and eliminates items further back?
As per MNR and others supply.
would it be difficult to glue (using hot glue so they can be easilyish removed) some thin plastic triangles?
(that would probably look better than gluing some ribs or spars over the gap so the sphere can't get through).
Along the same lines, have it vinyl wrapped. It would be like a balsa and tissue model aeroplane!
what does an msva retest cost, might be cheaper to see what it fails on exactly and then do anything like that if you need to?
Is this a new project smart is the cabin scooter finished if so why no pics ?
Bob
