Am working on the wiper mechanism and screen construction at present. Next job after that is a hood and cover the side screens when I have made the frames up. Does anyone know of a good company in the North that can do the work to fit my car? No problem with leaving the car with someone so long as its not too far away.
Mike
I used a local sail loft to make mine.
Its not cheap thou as the base materials cost 25 to 50 quid a square meter.
dont be tempted to use cheap materials as they just stretch and flop about.
70 mph is a lot of loading on a sailtop.
^^Ditto.
Get over to the local chandlery or sail loft. they will have the kit to do what you need.
Is Martrim too far?
http://www.martrim.co.uk/
[Edited on 31/7/10 by stevebubs]
Seems you may be forced to cross the hardknott pass to get to the nearest http://starturl.com/kizpi
