Touch up powder coat
chick - 2/6/04 at 01:12 PM
I would like to do something about the scratches and chunks I have taken out of my powder coated chassis whilst building.
Does anyone have any good paints for doing this? The powder coat is black.
Thanks,
Tim
jimgiblett - 2/6/04 at 02:46 PM
You could try Hamerite Satin Black, well its a very close match to colour and sheen on my chassis anyhow
Jim
Dave J - 4/6/04 at 10:11 AM
Hammerite smooth gloss black worked well, but I would advise you undercoat with red oxide primer first (I tried it straight onto the bare metal, it tends to chip off at the slightest knock).
I've also tried black gloss enamel, the stuff used on cookers, I think you can get that from B&Q. It tends to give a better finish, it flows better than hammerite and unlike hammerite doesn't dry too quickly, quite pricey though.
Both will do a good job for you.
Dave.
greggors84 - 5/6/04 at 01:27 PM
We used stonechip made by waxoyl, bought it in halfords. If you dont use a primer underneath it will come off very easy. We used halfords zinc primer, it seems just as good as zinc182 but cheaper. The primer always stays on, had a bit of a fuel leak and it took all the paint off, but the primer stayed on.
All the above available in spray cans too.
Terrapin_racing - 8/6/04 at 08:20 AM
Plastikote Metal paints do a fine job
http://www.plasti-kote.co.uk/Site/productsdetail.asp?PRODUCT_ID=25#
B&Q stock it
NS Dev - 15/6/04 at 03:05 PM
just to second terrapin, plasti-coat enamel applied to warmed metal gives an incredibly tough finish, looks good, excellent all round.
