Hinging bonnet on scuttle...
speedyxjs - 18/11/10 at 09:19 AM
... has anyone ever done it? If so, i would love to see some pics as i am thinking about doing that with mine
matt_gsxr - 18/11/10 at 10:27 AM
robinhoods do that I believe. Can't find a suitable image though.
Stott - 18/11/10 at 11:09 AM
It's called their "alligator" bonnet, the scuttle looks like it lifts as well:
YQUSTA - 18/11/10 at 11:13 AM
I wouldn't do it.
Just think what is going to happen should the bonnet lift at the front, the only place for it to go is into your face. Not nice IMO.
speedyxjs - 18/11/10 at 11:18 AM
Originally posted by YQUSTA
I wouldn't do it.
Oh, didnt think of that!
May have to do some rethinking. Thanks anyway guys
Benzine - 18/11/10 at 11:29 AM
Lambo door style bonnet?
Howlor - 18/11/10 at 11:53 AM
Hinge from the front to a vertical position? Or cut it in arf and a pair of leather straps around it?!
Blackbird Rush - 18/11/10 at 01:15 PM
Nice! so what happens if you have the roof up and need to stop and look under the bonnet.....
David Jenkins - 18/11/10 at 01:59 PM
I've seen a Robin Hood that had a bonnet hinged at the front - the only reason I remember it is that he'd used an inertia seatbelt as a retaining strap!
It worked very well, and gave clear access to the engine bay. I don't remember where the hinge was, as the nose didn't contact the road when the bonnet was up.
Canada EH! - 18/11/10 at 03:58 PM
Having had a rear mounted Frog Eye Sprite bonnet come up and over on me years ago, not a good idea.
There were two dents in one of the light pots when I pulled the bonnet back down, one from the single roll hoop behind my head and the othe from my head.
Don't do it.
Mave - 18/11/10 at 07:02 PM
Standard practice on RCB SeventySeven
montythemole - 15/12/10 at 03:10 PM
The Dutton does this which is great for access but you need a fair bit of room to lay it down:
See no reason why a rear hinged bonnet would be an issue, use some bonnet pins and it's safer than any modern car?
