Hi
Can you get an aeroscreen for a Sylva Striker? if so where from?
thanks
Raw do a 'modern' body style that has an aeroscreen, or you can cut down the screen on 'original' body.
Modern:
I would assume you would need the bonnet and the skuttle as well as some changes to the existing side panels to switch to this style.
Classic with cut down screen:
[Edited on 26/11/10 by loggyboy]
as above, the classic is just a cut down screen
if you want a cut down version, you can get them from raw direct.
£40 plus vat i believe, but thats a kit so you'll have to make it up yourself, but after that it's a direct change from the original
As said, classic style is easy. New style can and has been done but involves a lot of work including chassis mods.
