westy megabusa
just got the air box i bought from one of the guys on here fitted and just clearing the engine cover, now i need a air intake oval/ rectangular air
intake tract to the top of the air box.. cant decide if it will be a right faff on making a fibreglass one or making an ally one - if in ally i would
like it welding up properly tho.. not lots of rivets in it to come loose.. (the center pin of the rivets can fall out and into the engine - not
advisable)
i havnt much room to play with only bout 2-3 inches or so.. ideas?
the westy has a grilled intake built into the 'V8 engine cover' its a bike engine but called that. so that would make sense to use it
where is your air filter going in this set-up?
Have a look at my pics in my photo archive. The ducting was made from fibreglass sheet and just cut to shape using cardboard as a template. the whole
lot was glued together with a hot glue gun and when satisfied with the shape, i used sikaflex to bond it permanently. It's been fitted for 2
years now and still very strong.
No induction noise and more horsepower.
cosmick
Dont know if it is any ude.
Soren S2
Originally posted by cosmick
Have a look at my pics in my photo archive. The ducting was made from fibreglass sheet and just cut to shape using cardboard as a template. the whole lot was glued together with a hot glue gun and when satisfied with the shape, i used sikaflex to bond it permanently. It's been fitted for 2 years now and still very strong.
cosmick
Soren S2
thanks tho.. ps wheres the filter?
cosmick
Take the nose cone off and work from the front. First glue a piece of card to the airbox opening to get the angle up to the bonnet. Then make a V at
the other end to close the ducting. then place a flat sheet across the front of the bonnet and finally box it in. It took me about 4 hours to make and
it works brilliantly. Your airbox will be a less acute angle than mine but the principle is the same.
I don't understand why you had to cut some more off the top of the filter, I had that very box under my bonnet. I think your engine might be
higher in the chassis than mine.
Send me some pics when its done.
cosmick
[Edited on 28/12/10 by cosmick]
The filter is inside the hose as a cone.
Good for over 200 bhp.
Soren S2
