Hi ya, i am looking for some side repeaters like these below. I am sure i have seen a post before for the same type but cheaper, am i correct?
If so please can some one tell me where to get them from.
Many thanks
Just trying to work out how to add a picture
Cant work out how to add a pic to here is a
link
Many thanks
Hi there if u go onto Ebay shops Kit spares he sells them. Order some last week , where here within 2 days.
[Edited on 2-1-11 by davrus]
robin hood locost westfield IVA INDICATERS 1 pair LED on eBay (end time 22-Jan-11 22:19:57 GMT)
Cheers guys.
I seem to recall some one finding them some where cheaper than those on ebay but i may be wrong.
I will watch this space before i bye them just in case.
slightly cheaper
LED
can anyone confirm that i will have to have these repeaters on the front wings for iva as i really dont like them....
Originally posted by rayward
robin hood locost westfield IVA INDICATERS 1 pair LED on eBay (end time 22-Jan-11 22:19:57 GMT)![]()
you can fit them wherever you like so long as they comply with the IVA manual. IIRC they need to be visible from 5 degrees out, then 5 degrees down
from horizontal and 15 degrees up from horizontal, all viewed from the rear of the car. If they are visible from the front that is ok but some
inspectors misenterpret the bopok and say they CANNOT be visible from the front, whereas in fact there is no minimum requirement for frontward
visibility, only for rearward. It is due to the omission of a minimum forntward visibility that they wrongly assume they cannot be seen from the front
of the vehicle.
Mine are on stalks in the back of the headlamp bowls for now which satisfies the regs. Post test they will be flush mounted in the back of the
headlights
HTH
Stott
PS sorry for any bad spelling or confusion, I'm pretty drunk
edit; you can just make out the stalks in my avatar, they are made form 20mm conduit. There is a bush in the headlamp bowl that goes into a running
coupler outside it. Tehn a 100mm length of 20mm conduit outside threaded into the coupler and the indicators are push fitted into the end.
The happy coincidence is the indicator rubber grommets need a 20mm hole, so post test I can remove the conduit stalks and fit them straight into the
holes that are left over.
edit
[Edited on 2/1/11 by Stott]
