Hi all
Can anybody tell me if it is really necessary to have the vibration damper (on the MT 75 box) fitted after shortening the prop, I do not think
Westfields do have it?
Best regards Axle
I assume that your talking about the rubber donut, in which case no you don't need it. I have an MT75 box on my V6 and no donut fitted. HTH Ray
Depends on prop. If you have a Uj then no but there are some ie westfield that used the donut.
i have a westfield mt75 and that has one
Hi
I am talking about the wheel in the back of the dount. The rubber dount is part of the assembly and does need to be there! I do not have a UJ
either.
No you dont need it.
Thanks mate, it is alway a relief when you get the answer from another enthusiast!
[Edited on 11/3/11 by axle]
