Why? Just brought 150 cap headed bolts 12.9 grade to replace the ones on some split rims, torquing them up to 14 lbs/ft and I've snapped about a
dozen of them, but I'm not finding them until I inflat the tyre and check for leeks.
Why are they snapping?
Not the clearest of picture
Iain
Because 14 ft/lbs is too much unless they are M8 or above.
For M6 you want 12ft/lbs as a maximum.
M5 would be around 7 ft/lbs
Agree, too much torque.
Thanks for the replies, Image Wheels website said 12/14 lb/ft, so I thought tighter the better
If this has only just happened, why is the surface of the break on each bolt rusty?
They look rusty!!
