I'm about to embark on vinyl wrapping my car. The vinyl I will be using is graficast cast vinyl. Now the question I have is the suppliers also
supply this vinyl with an optional laminate (which I guess is just a clear layer)
The laminate more than doubles the cost and basically I'm wondering if its necessary or will the normal vinyl suffice?
cheers
it depends. on things like rear arches I can see single vinyl getting damaged from stone chips.
Its pretty thin stuff.
I had it on a bike with no problems, with no clear cover over it. So I can see it being fine on the majority of the car - just consider the rear
arches carefully.
I think they say it last 5 years...probably more on a kit that is in a dark garage/ not in daily use.
Vinyl wont last forever though.
The vinyl is only going to be used on the main tub of the car the aches are staying as gelcoat with the obligatory guards. The supposed life of the
vinyl is 7 years.
The rate I change my mind I envisage a colour change every winter anyway
My other concern is around the exhaust area, max working temp of the vinyl is quoted as 115 oC, how much of a gap is suggested around the manifold?
Are you applying the wrap yourself or getting it applied elsewhere?
I've been thinking of getting my car wrapped as I fancy a change of colour. What sort of price should I expect to have the whole car done
professionally?
Finally, do you need to inform DVLA of the colour change? I assume you do but as its a non-permanent application am I correct?
Now the question I have is the suppliers also supply this vinyl with an optional laminate
I will be doin it myself. i did have to get my scuttle done professionally as its curved all over the place. it was a local sign place who did it for
me they charged 60 quid including material. No idea how much a full wrap would cost.
Ive had a couple of practice runs and its pretty straight forward if you take your time.
vinyl wrap is technically only temporary, so you don't have to inform DVLA.
I probably would though to be honest...
I've had a few bits of my di-noc wrap unpeel and rest against the exhaust primaries. No significant damage done - obviously they melted and discoloured where they touched, but even 2mm away it was fine, surprisingly. With a 5-10 mm gap it shouldn't be an issue in the slightest, I would think.
I Have a Marcos Mantula That I have been thinking of wrapping. However the front end is one large peace that is two big for a single peace of wrap to cover. Does any one have a guyed to wrap application with joints?
There was a vid on YouTube of someone joining vinyl and it was pretty much invisible, of course you could always do the left and right half seperatly and use a racing stripe to hide it
I have wrapped a few cars with my job. If your just wrapping a solid colour then the overlaminate is a bit of a waste of time. Also as pointed out
above you need a wide format laminator to apply it to the vinyl before it goes on the car.
I would look at the HEXIS website. They do great car vinyls and also do a training course for a couple of hundred quid. You could go on the training
course, buy the vinyl and wrap it. You still have change over a respray!
