Forming the petrol tank
cjleonard - 12/9/02 at 01:17 PM
I'm just about to make the tank. I worked out the size (the book seems to be a few diamensions short!). However, I test bent a piece of the metal sheet I'm going to use - the good old fashioned hit it with a hammer approach - and it took some to get it over. This piece was no where near the size of the bit I need to form. So any tips on the best way to form it (read: cheap and easy - I want to avoid buying a tank)
Cheers Chris
theconrodkid - 12/9/02 at 01:54 PM
I made 2 before i came to my senses and bought one off locodude,sugest you do the same
ewanspence - 12/9/02 at 03:39 PM
Mine is bullet proof. 1.6mm thick. A bit too much if you ask me but the steel was kicking about.
I parked my Mazda MX6 front wheel on top of a scaffolding plank that was ontop to the steel. Then using a long crow bar I lifted the metal up. Just needed some persuading to finalise all the angles to exactly what I wanted.
Took a couple of hours t fully weld - including making the ends, baffle and slow drain at the outlet.
chrisg - 12/9/02 at 05:11 PM
Plasic Tank Man, every time
Chris
Ian Pearson - 12/9/02 at 05:20 PM
I used a Triumph Spitfire tank. Fits like a dream, and Greengauges sell a sender unit that is externally identical to the Spitfire one. I grafted it onto the old sender unit, and it works like a dream. Tank cost a fiver and the sender was £12.00 ish.
scutter - 12/9/02 at 05:26 PM
I have an old spirfire tank, free to anyone who wants to collect it at donington on saturday(no sender though)
Ian Pearson - 13/9/02 at 06:21 AM
I've a spare sender if anyone wants that tank! I'll be at Donington Saturday as well.
James - 13/9/02 at 11:01 AM
With your job is that the Triumph or Supermarine type?
James
Dunc - 13/9/02 at 11:45 AM
Locodude, whats the going rate for your tanks and do they come with the holes cut or can I make my own holes in them? How many litres can they hold?
