I am trying to layout my windshield supports etc. It will likely be a split screen with the center about 3 inches forward of the sides, and with a
40 degree rake.
If I was to glue the glass down as in a modern car, how wide a section would I need to glue down on the edges. If too much I may have to go with
the rubber seals?
Dale
Most modern cars, quite wide, usually more than an inch
Did about 10mm on mine,and it hasn't fallen out yet!
Chris
just remember to makesure the glass has a small gap to the frame (see below) when fitted else when you need to replace its hard to cut out with the
cheese wire and damages the surround. Guess how i know.
[img]
screen_gap
[/img]
regarsd Pete
As usual thanks a lot for the help. the one cm sounds perfect for the middle as I did not want it to have a wide strip down the center but that would
give me about an inch block out of the center including both sides and the center support.
Dale
