Is anyone building with an aim to fitting the GTS challenger bodywork? Does it fit the book chassis and will it get through SVA?
Thanks,
Mark
Thanks,
Mark
Have seen it mentioned before that the headlights are too low. Suggest getting the facts for yourself, but it's something to look into.
I'd imagine you could just jack the ride height up to hepl with the headlight height. Would be best to email Mark at Triton or Darren at GTS as
they both know about the car/moulds etc..
Ned.
quote:Hmm, good idea. I'll look into that.
I read that with the re-introduction of their Lotus 11 style bodywork Westfield have made some alterations to make it SVA compatible, but how was not specified. Maybe a call to Westfield would reveal what they had to do.
Westfield discontinued the production cause the headlights were too low I think, I asked the question months ago of Mark at Triton but didnt get a
reply
Shug.
does anyone, no what hight they need to be? and i will go messure approxiatly, 2morrow, or some time
silly suggestion, but if the lights are too low wouldn't bigger wheels lift the car up?
Originally posted by Hugh Paterson
Westfield discontinued the production cause the headlights were too low I think, I asked the question months ago of Mark at Triton but didnt get a reply![]()
Shug.
Minimum height of dipped beam headlight is 500mm. That's from the ground to the apparent trace of the beam cut-off on the lens. (whatever that
means!).
So get your tape out. Hope this helps.
Would it be possible to temporarily raise the ride height to satisfy sva and then lower again when you get home?
Mark
yes!!!
when the body was test fitted 2 day, (c http://locostbuilders.co.uk/viewthread.php?tid=16785 ) it messured 48cm, only 2 short of the sva standard,
which could easily b made up
heres the photo
Thanks Phil
[Edited on 25/8/2004 by I love speed :-P]
p.s. cus of this, i have desiced, to make it road legal
quote:Nice one, thanks for letting us know
Originally posted by I love speed :-P
when the body was test fitted 2 day, (c http://locostbuilders.co.uk/viewthread.php?tid=16785 ) it messured 48cm, only 2 short of the sva standard, which could easily b made up
p.s. cus of this, i have desiced, to make it road legal![]()
