hi need to secure my bonnet in two places to stop it rattleing when on the move, want something neat and tidy didnt really want big up and over catchs
like on the sides of the car
any ideas?
its either side of this inlet pipe
thank you
A nice sexy AEROCATCH would do the job or dowel pins from the bonnet into the nose cone.
http://www.aerocatch.com
[Edited on 21/8/12 by Toprivetguns]
I would suggest glassing something to the underside to make a lip...
+1 for aerocatch. they're simple to fit, flush, locking if you need it, weigh nothing.
like this one?
http://www.aerocatch.com/aerocatch3
Yup - I've got them on my fury, after my original fittings (I adapted TVR strikers and sliders so that I could mount the whole lot inboard and
make it look very neat. All well and good until the cables started popping off. Not TVRs fault I may add.
Then went to aerocatches - they're not expensive for the time and ease of fitting.
Originally posted by FuryRebuild
Yup - I've got them on my fury, after my original fittings (I adapted TVR strikers and sliders so that I could mount the whole lot inboard and make it look very neat. All well and good until the cables started popping off. Not TVRs fault I may add.
Just go hunting for the cheapest.
IIRC, they do a couple of different sizes, and locking or not. You have choices.
Mark
Mark
Aerocatches are massive though, you don't want one of them either side of that inlet it'll look weird in my opinion, get dzus fastners or
something subtle like that.
If you fancy aerocatches go ahead but check the dims first and cut some out of cardboard and lay em on the bonnet first. Once you've cut em in
there's no going back
atb
Stott
http://www.ebay.co.uk/itm/FLUSH-FITTING-CAB-LOCKER-LOCK-CAMPER-COACH-BUS-TRUCK-/310265962717#ht_1251wt_952
I used these on the boot of my indy
Jacko
[Edited on 21/8/12 by jacko]
Or this
http://www.ebay.co.uk/itm/Horsebox-Truck-Trailer-Flush-Compression-Latch-Lock-II-/200645519332?pt=UK_Horse_Wear_Equipment&hash=item2eb767a7e4#ht_5
00wt
Originally posted by Stott
Aerocatches are massive though, you don't want one of them either side of that inlet it'll look weird in my opinion, get dzus fastners or something subtle like that.
If you fancy aerocatches go ahead but check the dims first and cut some out of cardboard and lay em on the bonnet first. Once you've cut em in there's no going back
atb
Stott
Beaver
Sure - ping me when you're over. I'm rebuilding at the moment so there's lots going on.
I think Stott has a point - will you be happy with the size? Also, they take paint, so you can make them vanish a bit
thanks
mark
Beaver
thanks
mark
HI,
Have you got room to fit the Dzus fastners,Just need to check the depth of the material and order the correct ones from there. Demon Tweeks etc stock
them.
Hope this helps,
Chris.
BONNET BOOT HOOKS WESTFIELD CATERHAM 7 DAX LOCOST COBRA | eBay
what's wrong with these? They hold mine and others on very well, with no vibration problems.
Originally posted by RK
BONNET BOOT HOOKS WESTFIELD CATERHAM 7 DAX LOCOST COBRA | eBay![]()
They would with covers you could easily make.
At all ready been through sva in 04 so I'm lucky in that respect
fitted these, work fine abit of messing getting the length right though
just need to tidy all the bodywork edges now
