Does anyone have any idea where I might find a 50 degree sweep wiper motor? Or failing that one that much adjust down to this? Best I can find is 80
degrees
James
Use a mini one and drill the gear closer to the centre yourself and move the pin in, if you see one you'll work it out.
Hth
Stott
wot he said.... i reduced the movement on mine that way.... you havent got to move it much and the maths does not work out due to all the slack in my mini wiper system
OK yeah I see! thanks guys
