Hi guys just after some advice on cleaning up the fiberglass shell. I'm going to be vinyl wrapping the whole tiger avon but before I do I want to
repair some cracks and also fill some holes that are left from old lights, mirrors ect.
Can some one give me a list of the products I'd need and where I can get them at a good price.
Well the first thing to note is that there are two main types of resin available for fibreglass; polyester and epoxy. Any car shop (Halfrauds etc.)
will have a nominal DIY kit available that will have chopped strand matt (CSM), resin, hardener in it. Some might even have a thin wire mesh
included, or a surface tissue as well.
If it's just cracks in the surface you're looking to repair, i would suggest just getting some epoxy resin and hardener, gently opening up
the crack on the surface slightly, cleaning with acetone, and carefully filling the crack in with the mixture. A very crude analogy is repairing
render on the outside of houses. For those that wonder why I suggested epoxy resin, it's because "new" polyester resin doesn't
adhere too well to "old" resin, so to speak.
If the holes/cracks are more structural and go through the panel, my advice would be to patch the back of the affected area using epoxy resin again,
with the CSM (maybe mesh as well, depending how bad the damage is) to provide structural reinforcement. You can then decide if you wish to work on
the outer (visible) side with the above process.
I mentioned in the opening paragraph about a "surface tissue". This is for external use, to provide a smoother surface finish (in the
absence of a gelcoat - will explain shortly). Just remember that any sheet or extra material you add to the outer surface will require smoothing
in!
Gelcoat is a typical finish to GRP (glass reinforced polyester) panels for a coloured/smooth/UV resistant finish. This is not something that is easy
to do in terms of matching colours etc, and is probably not required in this case.
From what you've descrided, I'd say you want to glass the inside of the holes etc. with CSM and epoxy resin, then my advice would be to just
fill the holes/cracks from the outside using resin only, sand back to smooth finish, maybe put a touch of paint over them if you think it may show
through the colour of the wrap, then cover it all in vinyl!
That's just my 2p's worth, and I'm sure someone will come along shortly and tell you something totally different!
Charlie - there is no need to use epoxy in this application. The bodywork will be made of CSM and polyester, and this is what you want to use to
repair it with. If you have taken the time to sand/grind back the cracks, then you wll have no problem with adhesion. Just make sure you have gone all
the way back to the end of the crack and enlarged it a little before filling back in. You could look to use gelcoat filled with a little a little
talc, or colloidal silica - that will give you a paste, which will fill cracks very nicely. To be honest, regular car body filler will also do the job
(this is polyester based) if you have adequately prepared the surface (as Charlie says - abrade, then clean up with acetone before you start).
Also, Halfords etc is a very expensive way of buying fibre-glassing materials. Try CFS - they also have lots of
useful info on their website - give them a ring, and tell them what you want to do,
and I am sure they will give you just what you need for the job - and a lot cheaper than those kits from Halfords!
Originally posted by twybrow
Charlie - there is no need to use epoxy in this application. The bodywork will be made of CSM and polyester, and this is what you want to use to repair it with. If you have taken the time to sand/grind back the cracks, then you wll have no problem with adhesion. Just make sure you have gone all the way back to the end of the crack and enlarged it a little before filling back in.
Originally posted by Charlie_Zetec
You're probably right in this case, I'm just used to working in a more industrial environment with these materials! If it were me, I'd still want to use an epoxy resin, but then again I don't pay OTT money for materials as I work in the industry.....
Thanks for the info guys much appreciated
So to recap
Cracks
1- sand back to open up crack more
2- clean
3- fill with epoxy resin or gelcoat with talc
4- sand smooth
Holes
1- fiberglass sheet round the back
2- fill hole with epoxy resin or gelcoat with talc
3- sand smooth
Me too mate! What do you do? This is what I do!Skip to 1:30 and you can see the tool my team is just completing! She's a whopper!
So to recap
Cracks
2- clean
4- sand smooth
Holes
3- sand smooth
Originally posted by mcerd1
^^ small world, are you involved with the V90's aswell ?
(a few of our cutomers are building them at the moment)
quote:^^ not quite - substation design...
Originally posted by twybrowWe do all the R&D for all of the new blades (in particular my team is responsible for designing/delivering all of the composite tools for the manufacture of the blades) - the V90 is an older platform now, so not one I directly work on. I take it you work in the construction/installation side of things?
A good thing to so with cracks is to drill a small round hole (5-10mm) at the very end of the crack, this will limit the chance of the crack spreading further whilst being repairs and worked on, or even once its repaired.
Is this the kind of kit needed, I already have the sandpaper
Look at this on eBay:
Fibreglass Kit - 1 sqr m coverage - glass fibre repair
http://bit.ly/SYm46O
Or
P38 Easy Sand Car Body Filler 250ml & Fibre Glass Repair Kit & Grey Primer Paint
http://bit.ly/S01Vks
[Edited on 15/10/12 by Sierra]
Hi guys just after some advice on cleaning up the fiberglass shell. I'm going to be vinyl wrapping the whole tiger avon but before I do I want to repair some cracks and also fill some holes that are left from old lights, mirrors ect.
