The striker i just bought seems to have expanding foam splattered on the rear wing and back of the car. tried scraping it off with a plastic [non marking] scraper, tried polish, tried turps and paraffin. any ideas? it's taking ages!
Acetone will soften the PU - but you risk also marking the gelcoat if you leave it on too long.
Cutting is the only way really; very labourious.
ok, may try acetone, or a razorblade. it's very thin coating, like someone tried to wipe it off when it was spilt!
That stuff doesn't like to come off!
I used celi thinners, when i made my moulds, but dont leave it in puddles, !!
Worst case, sand it off with 600/800/1000 grit used wet on a block and then compound to get the finish back?
Fred W B
[Edited on 12/12/12 by Fred W B]
