44mm hole into a 47mm hole
jeffw - 30/12/13 at 08:47 PM
I have two 44mm holes in the bodywork of the Phoenix which need to be 47mm. What is the collectives thoughts on what is the best and cleanest/neatest way to do it....?
gregs - 30/12/13 at 08:53 PM
a big step drill if you need to keep the centre...
is it Steel or Grp?
[Edited on 30/12/13 by gregs]
HowardB - 30/12/13 at 08:53 PM
In grp? a rasp file.
wont take too long.,.. or you could get a bit of round wood and wrap it in P40 paper. The bigger diameter the wood the neater the job.
hth
[Edited on 30/12/13 by HowardB]
Ben_Copeland - 30/12/13 at 08:58 PM
I'd use my die grinder with small barrel sander or grinding stone.
Wheels244 - 30/12/13 at 08:58 PM
Piece of ally - Drill your 47mm hole in it - clamp it centrally over your 44mm hole then use rotary flap wheel in a drill and gently take it out the edge of the alloy hole - voilà nice round resized hole.
jeffw - 30/12/13 at 09:11 PM
Thanks for the suggestions....Do they do a stepper that big? It is GRP and right in the nose of the car.
britishtrident - 30/12/13 at 09:18 PM
If it is GRP then a 40mm dia drum style flap wheel in the end of drill , very cheap to buy in tool shops or ebay, but 6 times the price from B&Q.
stevebubs - 30/12/13 at 10:16 PM
conical piece of wood with sandpaper wrapped around it...
GOJO - 30/12/13 at 10:37 PM
Hole saw drill the pilot hole in a piece of wood and clamp behind in the centre then drop the hole saw drill bit into the pilot hole .
renetom - 31/12/13 at 08:09 AM
Hi
I have a 47mm hole saw (Starrett Type)
If you are not too far away you can borrow it.
René
jeffw - 31/12/13 at 10:02 AM
The holes are in the nose of the car so difficult to clamp behind. Flappy wheel seems the best bet.
