Show us yours!
Also how you did it and what's best to cut the alloy with, after doing mine next month
MKs have a huge gap round the suspenson beween the nose cone and side panel. This wasnt great in wet conditions when i had a distributor ignition (but
fine now with megajolt) but it does allow the hot airflow from the rad to exit. I havent vented any further back from there as the heat from the
exhaust exits round the gearbox to the rear and is not an issue.
[Edited on 12/2/2014 by Not Anumber]
Originally posted by Not Anumber
MKs have a huge gap round the suspenson beween the nose cone and side panel. This wasnt great in wet conditions when i had a distributor ignition (but fine now with megajolt) but it does allow the hot airflow from the rad to exit. I havent vented any further back from there as the heat from the exhaust exits round the gearbox to the rear and is not an issue.
Not fancy wide/flared side pannels. Thats my plan after iva.
Hi
I cut most of mine with a circular saw as most of the alu was straight cuts. To form the shape for the vents I made abit of a buck out of mdf
clamped the rough sized panel to it and beat it around it. Peened the sharp edges off around the mouth of the vent and trimmed the excess off.
Cut some holes in you're bulk head, might aswell have the warm air blowing on your rather than getting wasted ey
Side Panel Flare
This is what I did, tho mine is fibreglass. I cut down the panel and then stretched it out an inch. I was lucky that the side panels had 2 inch
returns top and bottom so it was easy. I couldn't be bothered to recut all the wishbone holes in another panel
I plan to mesh the hole so it looks tidier.
Originally posted by Matt21
Cut some holes in you're bulk head, might aswell have the warm air blowing on your rather than getting wasted ey![]()
I'm sure you don't need to see any more pics of my car, but here is one anyway…
Made from 2mm ally, however will be replaced soon with dibond as its far lighter
Hi
We did this on both sides of the bonnet
Works fine, less work & only in my opinion
Looks better.
Bonnet Vents both sides
good luck
Sorry to jump in on this thread, but do people just use a single flared side panel or do they add a second stressed skin underneath?
Thanks Dan.
The problem with just cutting the original fibreglass, and pulling it wider - is that all the lines of the car go squewiff… and provides no
overlap…
Add a second panel, allows you to join where the bonnet line is, and also provides you with a little overlap of around 5 inches
Anyone know if its iva friendly to have side pannels like yellowcabs as dont want to fail on something like that. I dont mind fitting trim that my fly off on the way back from iva but would it fail in general ?
How about boxing the rad in and exiting the air out the top of the nose cone?
Ive no room for bonnet vents
I have just changed the left front side panel to incorporate a vent. I just made a panel 1" bigger at the bulkhead end so it bulges out a bit. I used 1.5mm ally, and I cut it with a jig saw and a hole saw. The pics from start to finish are on my photo archive.
has anyone noticed a drop in temps at all?
