Looking at fitting a carbon fibre aero screen to my MK Indy, what would you recommend as the best fitting screen and best quality one on the market
Carbon mods do a double bubble one, which is suitable for the Indy.
I can supply a Double Bubble for you in Carbon , I can also supply a high level Aeroscreen for you , I have supplied the before for MK's with or
without the rear bracket fitted .
Please see the link : Aerodynamix Aeroscreens
Sorry to intrude
Julian; what is the highest that your aero-screens could be adjusted to be? My current one is around 60-70mm and just too low to do any good.
Hi Dave, no problem, there are some dimensions on the aerodynamix website, cheers Barry
Cheers Barry , please see the link for the right page on the website and there are a couple of photo's fitted too .
At an angle on with a bracket on the back they sit at 90mm standard height , I have supplied some without bracket for an MK (customers have bolted up
to the step)and they give more height than that as are sitting more vertically .
High Level Aeroscreen
Reserved a lovely carbon double-bubble from Julian
