I'm after a new headlight bulb for the Phoenix, as per the title, and struggling to find one.
Info on the bulb is...
Wagner 5731 37.5/60W Pilot.
Anyone know where i can get one?
Rocking horse droppings comes to mind.
But I may have one... I'll look tomorrow. If you can't get one, can you not convert to 5 3/4" lamps with H4 bulbs?
This would be a perfect post for the new Sylva section.
Or has that not been added yet?
Can't help with a supplier (there were some on e-bay, so you could contact that seller). Mine are wipac from SVC, so a slightly different.
Google sent me to this site, http://www.elta.co.uk/sealedbeams.html that has a matching number for a part that looks likely. But I guess you have
googled already.
Cheers chaps.
I could convert if I can't find one.
I swapped my standard /Lucas type lenses for these, surprisingly good and cheap too...
Crystal Halogen headlights kit lamp 5 3/4"' Westfield H4 headlamps lucas cibie
You'll need rear bowls too.
I had a look and although I do have 3 sealed beam units in a box, they're all 7". I found an Allegro headlamp as well!
Cheers for looking Adi.
Rang a few places today and discovered I can get some direct replacement H4 bulbled lenses, so should be sorted by next week.
