I cant get my head around what to do or a good solution.
There will be rubber bump stops along both edges only a couple to keep the shape and then id like it to latch shut at the top, really I only have that
lip you see available.
Anyone got any ideas.
Ive put the images as links below so i dont have to make them too small!
Photo 1
Photo 2
Photo 3
I would bond some of these onto the underside of the bonnet.
They slot into brackets like this..
http://oldgeebee.files.wordpress.com/2014/02/refurbished-passenger-side-bonnet-catch-assembly-3.jpg
Fit a pull cable and they pop open..
As fitted to most TVRs....
These are good.....I've used on central on my build:
http://www.jjcraceandrally.com/autograss/bonnet-pins-fasteners/pitking-products-quick-release-push-clip-latch
