fitting wheel arches
Harquil1908 - 13/11/14 at 02:28 PM
Hi all, quick question about fitting wheel arches.
how has everyone fitted there's? the manual i have says to fit with 5 bolts around the wheel arch but missing the chassis. now obviously some of the bolts will go into the back panel and wont be seen but some of the bolts will come through to the cockpit but will be behind the seats so wont be seen that much. just checking this is right or if there are other/better ways.
thanks
Daf - 13/11/14 at 03:43 PM
That's the way I've done it, I used some 50mm nylon washers on the back panel and inside the arch to spread the load on the fibergash though
Ben_Copeland - 14/11/14 at 06:19 AM
I'd use a few more than 5 tho.
I found if it's not well fixed then any stress put on the wing will rip the fixing out because theres a big gap till the next one. (Even with penny washers)
Go for a 7 maybe 8. You can always drill and tap the chassis if you do hit it.
Slimy38 - 14/11/14 at 11:24 AM
Could you use Sikaflex to help spread the stress? Although I guess it's more permanent than bolts?
steve m - 14/11/14 at 12:05 PM
Ive used 4 off 6mm pozi head screws, penny washers to spread the load and 6mm nylocs,
on the panel next to the seat, I glued some hardwood on the inside, and use large self tappers , plus penny washers
ive also made a connector just inside the boot for the lighting wiring, to be disconected
Never had a problem, in removing an arch or re attatching it, and also never had a problem with it moving
Ben_Copeland - 14/11/14 at 12:58 PM
No don't stick them on, just incase you need to remove one in future.
Smoking Frog - 14/11/14 at 01:19 PM
Have them removable, gives better access for setting up suspension, bleeding rear brakes etc. For fixing I used the bolt equivalent of a rivnut (rivbolt?) into the chassis members and bolted from the inside in the rear tub area. If you bolt from the arch side it is very difficult to line up the holes. I have five fixings in mine, seem sturdy enough.
rodgling - 14/11/14 at 03:23 PM
Agree, I would rivnut the chassis / bodywork as it's a huge pain to reach round the arch and access both sides to do up a nut and bolt.
Harquil1908 - 14/11/14 at 05:35 PM
Thanks for all the reply's guys. The rivnut into the chassis way does sound the best and neatest idea to me tbh. Know the bolts would be hidden by the seats but still not great.
