Other than MK themselves, what full screens have others used that fit the MK scuttle??
Considering fitting one to mine although I have full cage - has this been done by anyone before?
Thanks,
Matt
caterham one fits,
like this
Hi thanks for the reply (lovely looking car) but the Caterham one is even more expensive than MK!!!!
I made a frame, fitted to the car and then got the glass cut to size. I brought the frame of GBS and the glass cost £30.00 ( laminated)
Does the GBS one fit or did you have to modify?
You buy the top rail that can be opened or closed and bend the bottom rail to suit the scuttle.
i know where you can get one 2nd hand with a set of new uprights and new glass for it,
If any good drop me a u2u,
thanks
sean
I bought a Caterham one with cracked glass and had a piece of 4mm laminate cut for about £35 iirc.
It fits really well.
Stu
