hey up
can any body recommend any products that can be applied to the underside of GRP to seal the fibres from water etc.... as im intending to use my car
all year so dont want it blowing off in the frost!!!
i have seen some rubber soloutions to stop stones causing spiders legs on the upper surface.... any comments on this project!!
cheers
bob
wonder seal svc i think
I'm going to use brushable seam sealer, its PU, and best stuff you can get for the job
http://www.nfauto.co.uk/wunderseal.htm
Bob, best thing to seal the surface is "Flowcoat" 50% gelcoat +50% General purpose resin mixed together. Two thin coats, second applied as
the first un goes throught the green stage. If the layup has been done correct and the CSM is well wet through and laminated properly it shoudnt need
weather proofing though Tust me I aint had a failure or osmosis on my stuff in 30 years.
Shug.
I got a catalogue from Frost yesterday. They have it.
http://www.frost.co.uk/item_Detail.asp?productID=8323
Mark please tell me more. Where what when and how much?
how does it stick to GRP and aluminium ? I'm thinking of perhaps doing the entire underside of the car with something like this. Last thing I
want is the stuff peeling off.
Originally posted by givemethebighammer
how does it stick to GRP and aluminium ? I'm thinking of perhaps doing the entire underside of the car with something like this. Last thing I want is the stuff peeling off.
I got some "grey stuff" from Halfords. Oily thick black sticky shit. Cheaper than all the rest and did the job on my car.
Pat...
known in the trade as 'black dog sh*t', normally used by bodgers to disguise bad patch welding.
It tends to crack in time, and impossible to remove
Pat...
