Is this the poo (I didn't say POO btw!) to buy to cover my plug before final sanding?
Duratec Gray Surfacing Primer - Perfect for Plug Finishing and Hiding Repairs
http://www.fibreglast.com/showproducts-category-category-22.html#12
Or is there something else that is better?
I looked for a product called DuraBuild, but AFAIK it's a UK only product? (I'm USA based)
Alan B. used a home improvement product called Kilz hi-fill primer and it seemed to work ok, but is this Duratec really special?
Graber
Mr. G. I used to use stuff called Featherfill epoxy primer, Hi build and really stinky stuff. I use Nason (dupont)Urethane primer now that will hide
80 grit scratches...
David.
Came across this the other day, don't know if it's much use as you're in the US, but here it is anyway!!
http://www.bodyshopwarehouse.co.uk/
i just used ordinary body filler - then went over it after sanding with a water based varnish to seal it.
as always, its on my site
atb
steve
[Edited on 16/12/04 by stephen_gusterson]
i use , upol reface - a high build polyester based paint , its thick so you can brush it on - i recomend you spray it on , its cheapish aswell , and
can be treated like normal paint - ie it can be made to shine quite well .
that picture has a blue marker coat prior to sanding .
[Edited on 16/12/04 by Volvorsport]
Steve will have a decko at the spec sheet tomorrow, I suspect that duarbuild is manufactured in the states as its supplied in U.S. Gallons, if i find
out where will let u know tomorrow. What u paying for the upol, durabuild aint cheap??
Shug
Ho Ho HO methink's yon Duratec is the same stuff with a different label to the tins we get supplied over here, bluddy dummy should have looked
at the link first
Shug.
Originally posted by Hugh Paterson
Ho Ho HO methink's yon Duratec is the same stuff with a different label to the tins we get supplied over here, bluddy dummy should have looked at the link first
Shug.
I hope u put too much catalyst in and you bung up yer spray gun hoo hoo (been there), less said bout that the better
Shug.
