Hello there,
I would like to fit some aluminium mesh vents in the body of my car, but would like to have the mesh bonded from the inside and stretched to sit flush
with the outer surface of the fibreglass. Would the best way to do this be to cut a template to the shape of the vent from MDF and then press (or
hammer) a smaller blank into the shape? Is it necessary to anneal the aluminium first?
Any advice would be greatly appreciated. Also, has anybody got any photos of this being done - or of the finished product?
Thanks,
Peter
If this works ill be amazed, its been ages since ive done owt like this.
http://locostbuilders.co.uk/forum/4/viewthread.php?tid=115155
Thanks very much!
Hi I have a full set (4) of the Westfield FW body work pre formed mesh vents - possibly not aluminium though let me know if your interested can send some pics.
Originally posted by L1berator
Hello there,
I would like to fit some aluminium mesh vents in the body of my car, but would like to have the mesh bonded from the inside and stretched to sit flush with the outer surface of the fibreglass. Would the best way to do this be to cut a template to the shape of the vent from MDF and then press (or hammer) a smaller blank into the shape? Is it necessary to anneal the aluminium first?
Thanks,
Peter
Hi Martin - that looks ace - where did you source the mesh from?
Thanks,
Peter
I used stainless mesh from Ford (as used on the < 2001 Mondeo front end) when I did my nosecone, and will probably use the same if/when I do any vents in the bonnet. It's a woven look, so not sure how well it'd take to being hammered/formed around a mould of any description??
Thanks,
Peter
as I suggested in this thread
http://www.locostbuilders.co.uk/viewthread.php?tid=198102
have a look in a local junk shop / antiques emporium or possibly charity shop, and see if they have any fireguards. and cut the mesh from that
great idea
