Classic mini wheels centre size
bozla - 5/4/19 at 01:44 PM
Does anyone know the size of the central hole in a classic 10 inch mini wheel please?
Big T - 5/4/19 at 02:00 PM
Do you mean the centre bore?
I’ve got a lot of mini wheels I can measure for you.
bozla - 5/4/19 at 03:48 PM
Yes, that's it. Many thanks.
bonzoronnie - 5/4/19 at 06:52 PM
Just measured a classic min rim from my scrap pile
My vernier says 2.59 inch, also measured a mini hub unit & that came out as 2.59 inch same as the rim.
PCD 4 X 100 if I remember correctly.
HTH
[Edited on 5/4/19 by bonzoronnie]
bozla - 5/4/19 at 07:19 PM
Thank you so much for that. The centre bore on the hubs I have (4in pcd) is 64mm. Phew!
Big T - 6/4/19 at 08:22 PM
I had a measure earlier. Not with my vernier unfortunately but I’m getting 62/63mm acros 10” 12” and 13” wheels.
PCD is 4x4” or 101.6mm. So wobble bolts will take up anything.
bozla - 7/4/19 at 02:51 PM
Looks like Weller do a wheel that would suit.
Weller A35
bonzoronnie - 8/4/19 at 06:27 AM
Austin A40, that's a blast from the past.
My very first car.
Bit of a rust bucket but £15 with 6 months MOT
That was my bad, should have remembered that the Mini PCD was 4 x 4"
Those rims looks as if they will do the job Nicely.
