Adjustable passenger footrest
John G - 3/8/21 at 12:34 PM
I have an angled aluminium passenger footrest. Has anyone any links to a means of making this adjustable? rather than moving the seat back and forth?
Regards Jon
SteveWalker - 3/8/21 at 03:37 PM
A couple of slim seat sliders?
nick205 - 4/8/21 at 07:43 AM
Failing the seat slider idea you could try some holes in the car floor, holes in the foot rest and metal pins dropped through secured with R clips under the car. If you ground out you'll risk damaging the pins and R clips though and may make them difficult to get out.
On balance I'd probably stick with using the adjustability of the seat if it's already there.
Slimy38 - 4/8/21 at 08:48 AM
My Skoda has footrests for the rear passengers, it's attached to the floor by velcro, and it works perfectly fine. I'd be tempted to do similar in your case, a couple of velcro strips on the floor and the matching strip on the footrest. Velcro is surprisingly strong when attached to flat surfaces and subjected to lateral forces.
pewe - 4/8/21 at 10:34 AM
That's what I did with mine - loop side onto the ali floor, hook side on the rest so its less likely to collect dirt. You need to use a fairly wide velcro though to resist passenger pushing it free. I attached the velcro using Evo-stik - other adhesives are available.
From memory I bought a shoe rack from IKEA which is perforated galvanised thin steel which already has an angle bent into it so sits at a good angle.
Cheers, Pewe
David Jenkins - 4/8/21 at 10:56 AM
You can get velcro-like stuff made by 3M - both sides are identical, but the grip is amazing.
3M dual lock
It comes in tapes, pads, etc.
Charlie_Zetec - 5/8/21 at 11:14 AM
3M dual lock
I can confirm this stuff holds - have used it previously on headlight protectors on motorbikes, as well as securing a GoPro (with a backup tether, before anyone suggests being unsafe!) to a helmet. Never had anything come adrift!
David Jenkins - 5/8/21 at 11:36 AM
I used to use it for fastening LiPo batteries to the underside of multirotor aircraft - I did also have a retaining strap but it was never needed, despite many crashes!
[Edited on 5/8/21 by David Jenkins]
nick205 - 5/8/21 at 12:16 PM
3M dual lock
3M do make some pretty good stuff - better performaing than other brands.
We use it at work to secure assembly jigs to work benches - the jigs simply don't move - it prevents having to drill holes in the jig and the bench to bolt the ji to the bench (saves time too).
