I'm after some ideas... here's my rear end;
The smaller hole halfway up is 45mm, then I have two gaps for 70mm lamps. But I can't find an e marked fog lamp that would fit in either. Is
there any other option for adding an appropriate fog light?
[Edited on 14-11-23 by Slimy38]
could you fit it on the roll bar?
Would that pass IVA?
I just checked, only if it is below 1metre, (or 1.2m if you mount the other lights there too.)
The real question is how do you get to your car?
From underneath! The 70mm lamps - do they not do these with a built in fog light (at least to one side)?
Fair enough - I figured you'd probably have checked.
Different car and SVA not IVA when I did mine, but IIRC it only required an "E" mark.
Likewise - in the 3 years I drove my Indy before selling up, I don't recall ever driving in fog. It was a means of getting through the SVA test.
https://www.carbuilder.com/uk/55mm-led-fog-light
This any use?
And have you checked the manual, do they have to be E marked ?
[Edited on 1 by Schrodinger]
This any use?
Just looking at the photo that is E marked but check with CBS.
