Which type of rubber have you put between an aluminium bonnet and the scuttle + nosecone?
Has someone perhaps pictures?
Better than my Dutch, I've used a U shaped rubber trim about 19mm wide,sorry have no pictures. Think I got it from Woolies at a show somewhere
Try here, as above, have anything you need............
http://www.woolies-trim.co.uk
dr-fastlane,
interesting avatar. Are you fitting full bonnet or just a half size one???
Im using u trim around bonnet edge but im also using foam tape around the scuttle, top of chassis and nose cone where the bonnets will sit.
How about a strip of thin rubber under binnet on top of scuttle/nose cone, old bicycle inner tubes could be ideal and 'low cost'. Just stick
the tube to the under side of the bonnet with suitable glue.
Or cut strips from old car inner tubes etc.
[Edited on 23/3/05 by clbarclay]
Hello
I'm using foam tape, it compresses down nicely .
DarrenW: That photograph on my avatar is taken when I cut an Viento noscone in half and made it fit my +9 inch wide chassis. The bonnet is gone be an
full size one.
I think that i gone use U- shaped trim like on the image below.
[Edited on 24/3/05 by dr-fastlane]
I presume the lower part of the diagram ilustares how tight a radious the trim can go round, if so what is the units cm or inch?
clbarclay: the upper drawing is in mm and bottom in cm
[Edited on 27/3/05 by dr-fastlane]
I used sticky back insulation tape about 4 mill thick,just the job.
Bob
last weekend I have received the U-shape trim for the bonnet and foam that i use for the nosecone + scuttle.
now I have to made an cover for the EFI
I bought some extruded rubber called 'fender weld' which is used for beetle fenders, looks good, and its cheap over here.
